could it be possible to make a slider or sort of to adjust the intensity of the subtitels?
because sometimes its really bright.
Is it only an issue with HDR?
Mostly yes,but also on 1080p.
The different color options dont work exept for yellow.
Can you upload a sample of a 1080p SDR clip that is affected?
i adjusted the color and then rebooted the vero and now it seems better, the subtitle turned grey.
Sorry for the question, im just exploring and testing out different settings of the vero.
Love the machine by the way!
Plays everything nice and smooth even high bitrate 4k rips .
I’m glad it’s working well for you.
