When I’ve booted to Android on the Vero 2, the display seems to be larger than the actual screen. Is there somewhere where I can adjust the screen size, not the resolution, just the size?
Ideally, you should use 1.1 pixel mapping to avoid this problem. It may be called Just Scan on your TV.
You should also be able to change the ‘zoom’ under the Settings application, where you can configure WiFi etc.
Ah thanks! I found the just scan option on the LCD screen.
