I was wondering if there was an easy way to lock out content using osmc?
Basically want to protect my kids from any rated above pg (so their content is still accessible and as for the higher ratings, I would prefer no cover or fan art until unlocked with a pin or something)
I used to use separate profiles in the past (xbmc) or just not pull the content from the network.
Thanks!
