Hey there,
just set up OSMC on my Raspberrypi 2. Works like a charm.
I have media on a remote server reachable via pptp vpn. Hence I installed the VPN client following the instructions at
http://forum.osmc.tv/showthread.php?tid=1754
They suggest using the addon Advanced Launcher to invoke linux scripts from within XBMC.
Now my question: Is there any way to invoke the command line script to establish the vpn connection from within OSMC.
I don’t want the VPN connection to be established on startup. That would be no alternative.
Best regard
tola
