Hey,
Latest Vero4k here, OSMC March 2022.03-1 Kodi 19.4
I have a big issue with Youtube videos from the Youtube plugin, many of them are like this for example: Am-Vp9 3840X1920 px 2.00:1 23.976
Deinterlace method hardware
This specific frame rate on 3840X1920 and pretty much all other resolutions I tried causes very bad audio skips and basically video is unwatchable unless I manually set to a resolution with 59.94 frame rate
All 23.98 resolutions I already blacklisted. But there is one left, 4096X2160p @ 23.98 and every stupid 23.98 video, even very low res, will now auto switch to it! I cannot remove this resolution, because I often watch 4k HDR movies that need it. My TV cannot do 4096X2160p @ 59.94 so the only options left is to either change manually all the time which is very annoying or give up my 4k tv max resolution and watch every 4k content on max 3840X2160p 59.94
Is there any way to modify this behaviour with some advanced configuration from the console, etc? Any ideas much appreciated!
reproduce the issue
upload the log set (all configs and logs!) either using the Log Uploader
method within the My OSMC menu in the GUI or the ssh
method invoking command grab-logs -A
Thanks a lot Sam!
I did exactly as instructed. This is the log: https://paste.osmc.tv/uhayulocid
There’s bug which means a 4k resolution video with a 44.1k PCM soundtrack doesn’t play well. Workaround is to set audio output to Fixed with 48ks/s.
With that 3840x2160p24 should play fine. Please see if that solves the problem or post logs again for a problem video.
Ahh, that solved the problem, on fixed 48Khz now those videos play like a charm, I enabled all 23.98 configurations. Many thanks @grahamh !
