Just wondering if someone could point me in the direction for the most optimal HDR settings?
I have an LG OLED TV, the video content is HDR but im seeing really washed out colours, a couple of examples below;
HDR Example 1:
Non-HDR Version:
HDR Example 2:
Non-HDR Version 2:
The settings Ive set so far:
Settings>System>Display>Resolution> 1920x1080p
Settings>System>Display>Whitelist> (empty) *
System>Display>Force 4:2:2 colour subsampling> enable (also tried disabling this).
Media Info for HDR File:
General
Unique ID : 313827220691932529848893926263288259085 (0xEC18EC965E56F3A0E3C464E02290620D)
Complete name : V:\Movies\Kids\Encanto\Encanto.mkv
Format : Matroska
Format version : Version 4
File size : 16.5 GiB
Duration : 1 h 42 min
Overall bit rate : 23.1 Mb/s
Writing application : mkvmerge v63.0.0 ('Everything') 64-bit
Writing library : libebml v1.4.2 + libmatroska v1.6.4
Video
Format : HEVC
Format profile : Main 10@L5@Main
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 22.4 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.112
Stream size : 15.9 GiB (97%)
Writing library : x265 3.5:[Linux][GCC 9.3.0][64 bit] 10bit
Encoding settings : cpuid=1111039 / frame-threads=1 / numa-pools=16 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x2160 / interlace=0 / total-frames=0 / level-idc=50 / high-tier=0 / uhd-bd=0 / ref=3 / no-allow-non-conformance / repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=48 / keyint=48 / gop-lookahead=0 / bframes=2 / b-adapt=1 / b-pyramid / bframe-bias=0 / rc-lookahead=48 / lookahead-slices=8 / scenecut=0 / hist-scenecut=0 / radl=0 / no-splice / no-intra-refresh / ctu=32 / min-cu-size=8 / no-rect / no-amp / max-tu-size=16 / tu-inter-depth=2 / tu-intra-depth=2 / limit-tu=0 / rdoq-level=1 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=3 / limit-refs=1 / no-limit-modes / me=1 / subme=2 / merange=44 / temporal-mvp / no-frame-dup / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / no-sao / no-sao-non-deblock / rd=4 / selective-sao=0 / early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / no-splitrd-skip / rdpenalty=1 / psy-rd=1.60 / psy-rdoq=5.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=abr / bitrate=23000 / qcomp=0.75 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=25000 / vbv-bufsize=25000 / vbv-init=0.9 / ipratio=1.40 / pbratio=1.30 / aq-mode=3 / aq-strength=1.00 / no-cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=0 / display-window=0 / cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.00 / hist-threshold=0.01 / no-opt-cu-delta-qp / no-aq-motion / no-hdr10 / hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / no-scenecut-aware-qpconformance-window-offsets / right=0 / bottom=0
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Audio
Format : E-AC-3 JOC
Format/Info : Enhanced AC-3 with Joint Object Coding
Commercial name : Dolby Digital Plus with Dolby Atmos
Codec ID : A_EAC3
Bit rate mode : Constant
Bit rate : 768 kb/s
Channel(s) : 6 channels
Sampling rate : 48.0 kHz
Compression mode : Lossy
Stream size : 561 MiB (3%)
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
Complexity index : 16
Number of dynamic objects : 15
Bed channel count : 1 channel
Bed channel configuration : LFE
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 1 h 36 min
Bit rate : 71 b/s
Count of elements : 1600
Stream size : 50.8 KiB (0%)
Language : English
Default : No
Forced : No
Text #2
Format : UTF-8
Bit rate : 82 b/s
Count of elements : 1838
Stream size : 58.0 KiB (0%)
Title : SDH
Language : English
Default : No
Forced : No
Text #3
Format : UTF-8
Duration : 1 h 40 min
Bit rate : 55 b/s
Count of elements : 973
Stream size : 41.2 KiB (0%)
Language : Danish
Default : No
Forced : No
Text #4
Format : UTF-8
Bit rate : 54 b/s
Count of elements : 1292
Stream size : 40.3 KiB (0%)
Language : German
Default : No
Forced : No
Text #5
Format : UTF-8
Bit rate : 58 b/s
Count of elements : 1211
Stream size : 43.4 KiB (0%)
Title : Latin American
Language : Spanish
Default : No
Forced : No
Text #6
Format : UTF-8
Bit rate : 53 b/s
Count of elements : 1189
Stream size : 39.3 KiB (0%)
Language : Spanish
Default : No
Forced : No
Text #7
Format : UTF-8
Bit rate : 55 b/s
Count of elements : 1208
Stream size : 40.7 KiB (0%)
Language : Finnish
Default : No
Forced : No
Text #8
Format : UTF-8
Bit rate : 62 b/s
Count of elements : 1259
Stream size : 46.1 KiB (0%)
Title : Canadian
Language : French
Default : No
Forced : No
Text #9
Format : UTF-8
Bit rate : 54 b/s
Count of elements : 1136
Language : French
Default : No
Forced : No
Text #10
Format : UTF-8
Bit rate : 58 b/s
Count of elements : 1212
Stream size : 43.5 KiB (0%)
Language : Icelandic
Default : No
Forced : No
Text #11
Format : UTF-8
Bit rate : 56 b/s
Stream size : 41.7 KiB (0%)
Language : Italian
Default : No
Forced : No
Text #12
Format : UTF-8
Bit rate : 51 b/s
Count of elements : 1296
Stream size : 38.1 KiB (0%)
Language : Japanese
Default : No
Forced : No
Text #13
Format : UTF-8
Duration : 1 h 30 min
Bit rate : 60 b/s
Count of elements : 1220
Stream size : 40.1 KiB (0%)
Language : Korean
Default : No
Forced : No
Text #14
Format : UTF-8
Bit rate : 45 b/s
Count of elements : 1147
Stream size : 33.6 KiB (0%)
Language : Dutch
Default : No
Forced : No
Text #15
Format : UTF-8
Bit rate : 53 b/s
Count of elements : 1201
Stream size : 39.8 KiB (0%)
Language : Norwegian
Default : No
Forced : No
Text #16
Format : UTF-8
Bit rate : 59 b/s
Stream size : 43.6 KiB (0%)
Title : Brazilian
Language : Portuguese
Default : No
Forced : No
Text #17
Format : UTF-8
Bit rate : 50 b/s
Count of elements : 1179
Stream size : 36.9 KiB (0%)
Default : No
Forced : No
Text #18
Format : UTF-8
Bit rate : 45 b/s
Count of elements : 1025
Stream size : 33.9 KiB (0%)
Language : Swedish
Default : No
Forced : No
Text #19
Format : UTF-8
Bit rate : 44 b/s
Count of elements : 1226
Stream size : 32.5 KiB (0%)
Title : Cantonese
Language : Chinese
Default : No
Forced : No
Text #20
Format : UTF-8
Bit rate : 50 b/s
Count of elements : 1225
Title : Simplified
Language : Chinese
Default : No
Forced : No
Text #21
Format : UTF-8
Bit rate : 43 b/s
Count of elements : 1241
Stream size : 31.7 KiB (0%)
Title : Traditional
Language : Chinese
Default : No
Forced : No
Menu
01:41:28.714 : en:Credits
Media Info for Non-HDR file:
General
Unique ID : 311573825979466643264280880792483973104 (0xEA66EFA67C41AA7B1E76F00F093CC7F0)
Complete name : V:\TV Shows\Adults\1 - Encanto.mkv
Format : Matroska
File size : 4.19 GiB
Overall bit rate : 5 874 kb/s
Encoded date : UTC 2021-12-23 15:20:56
Writing application : mkvmerge v25.0.0 ('Prog Noir') 32-bit
Writing library : libebml v1.3.6 + libmatroska v1.4.9
Video
Format : AVC
Format profile : High@L4
Format settings : CABAC / 2 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 2 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 5 489 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.110
Stream size : 3.91 GiB (93%)
Writing library : x264 core 155 r2901 7d0ff22
Default : Yes
Forced : No
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : E-AC-3
Codec ID : A_EAC3
Bit rate : 384 kb/s
Stream size : 280 MiB (7%)
Language : English
Default : Yes
Forced : No
I appreciate HDR and non HDR are mastered differently but I wouldnt have expected it to look quite so washed out. Is there anything obivous I’ve missed?
