Hello all,
I’m interested in getting a Vero 4K.
Right now I use a ChromeBOX and a NUC D34010WYK (for 3D movies).
I use the skin Aeon Madnox on both.
It’s a pretty demanding skin and I was wondering if any of you are using it and how it performs on the Vero?
Or if someone feels kind enough and has a few minutes to spare Maybe you could give it a try and report?
'resource.images.studios.coloured' required by 'skin.aeon.madnox' is missing.
'script.image.resource.select' required by 'skin.aeon.madnox' is missing.
'script.skin.helper.service' required by 'skin.aeon.madnox' is missing.
'script.toolbox' required by 'skin.aeon.madnox' is missing.
Will install these and test it again when i get home this evening
Hmm,
I’ve been using Madnox on Krypton for months now on my 2 boxes and I can assure you it’s not experimental.
Anyway, thanks for giving it a try!
I will probably order the Vero and hope for the best!
I ordered a Vero 4k yesterday as my Intel NUC is becoming sluggish. I have been using Aeon Madnox on my NUC for about 2 years now. It’s easily the best skin I’ve ever seen and the little differences in style, menus and displays are perfect…so this thread will become useful for both of us it seems. I’ll keep an eye on it. Thanks
I got my Vero 4k a few days ago and I’ve been testing Aeon Madnox since then and I can say that I’m pleasantly surprised!
Of course it is not as smooth as my ChromeBOX (wish it would do 4K UHD) was but it’s night and day compared to the Odroid C2.
The C2 was sooo sluggish with Madnox it was unusable. The Vero only lags a bit compared to the ChromeBOX. Mostly when the box is restarted and you want to access a menu for the first time, you get a black screen for a few seconds and then you see your library or whatever.
My only issue with the Vero 4k is when I fast forward or rewind a video. If I go to 8x for too long, I just get a black screen and I have to stop the video and resume it. And that happens to 720p or 1080p videos, so it’s not like if it was high bitrates files…
Issues I never had with the ChromeBox or my NUC…
Anyway, so far I’m very pleased with the box and looking forward to the coming 3D Frame Packed!
