Aeon Nox Silvo Movie view vs Movie Sets view
Hi all,
I appreciate that this issue may be Kodi/Skin related. I’ve posted in the Aeon Nox subforum on the Kodi forums but I’m not getting any replies.
I’m running the Aeon Nox Silvo skin on an OSMC Vero 4k+.
My preferred view for Movies is Fullscreen Wall. My preferred view for Movie Sets is Tripanel.
I used to be able to set these independently. Movies would always display as Fullscreen Wall and when accessing a Movie Set, the films within it would display as Tripanel. I had to set each movie set to show as Tripanel - not ideal but at least it worked.
This no longer seems to be the case and I can’t have different views for Movies and Movie Sets. They will only display as either Fullscreen Wall or Tripanel.
Has something changed ?
Not to be difficult but no clue about this skin.
I’m sure someone else here is using it though.
I think the OP got the answer in the Kodi forums, if anyone is looking for it it’s at Problem with Movie view and Sets view
Thanks @flitter2009. I’ll be testing the fix later !
Disabling the Skin Variables addon has resolved the issue, as per the Kodi forums thread posted above.
