After playing any movie with DV, 3D movies no longer play correctly. One of the eyes has a pink hue. If I reset the Vero V, then 3D will play normal until I play another DV movie. This did not happen before the current update.
Thank you,
Steve
Thank you,
Steve
That’s a known issue. It’s already on my todo list. Meanwhile, a quick fix/workaround: rebooting helps
Hopefully the issue is now addressed
echo 'deb http://apt.osmc.tv bullseye-devel main' | sudo tee /etc/apt/sources.list.d/osmc-devel.listPlease see if the issue is resolved.
I also recommend you remove /etc/apt/sources.list.d/osmc-devel.list after updating.
This will deactivate the staging repository. You can do so with the following command:
sudo rm /etc/apt/sources.list.d/osmc-devel.list.
