After the last 2023 update on my Vero 4K, most of my upnp file shares from my nas no longer show up. When I edit the share source I can browse the file structure - everything shows up there. I create a link to the share, but the files and folders don’t show in the skin. Everything has worked fine for literally years and even odder, one of the shares still shows up and plays fine. Any help here?
See this thread for more details on the issue. A fix for the OSMC skin has been tested and should soon be available. In the interim you can switch skins or use another UPnP addon mentioned in the thread. What UPnP / DLNA server are you using ?
Thanks,
Jeff
Thanks for the reply Jeff! The Kodi update in the link you sent fixed the issue.
