prior to the update, 1080p .ts files would play without a hiccup over the network and on the pi directly attached to the hard drive. now, it stutters and there is severe a/v sync problems. this problem occurs on both over the network (ethernet) and with the pi with the hard drive with the file directly attached.
Hi Sam. thanks for the quick reply. I do have the MPEG 2 license and it is enabled.
One more thing. It appears so far that every other type of file (blu ray and dvd - all saved as mkv files) work perfectly. of course i haven’t tested every file but these (.ts) are the only ones that seem to have this problem.
Thanks Sam. I changed to MMAL - Bob and that fixed it! Awesome!
I also changed it so that it was set to default.
Is there a way i can change it so that it will only be default for these type of files?
that unfortunately sets it for all video files, not just the .ts files. any way to set it just for those files so that the others aren’t changed? thanks!
