Just upgraded to latest release but now dont have any settings menu. Only the standard menu options eg movies, tv, and custom ones I created. I also notice the picture is only 480p! How can I change the resolution via ssh as I believe changing the resolution may then display the settings menu or do I have a different issue? Thx
Got it displaying 1080p now by the following…
mv .kodi/userdata/guisettings.xml .kodi/userdata/guisettings.xml.backup
Still no settings menu!
Could you try to following?
Login via ssh
rm /home/osmc/.kodi/userdata/addon_data/script.skinshortcuts/skin.osmc.hash
systemctl restart mediacenter
I ended up resetting whole config and starting from scratch as it was a customized setup with some now out dated addons and skins etc
