when I enable airplay in Kodi it works fine, actually works very well. I can send audio from an iphone, ipad and mac.
But everytime that I reboot the raspberry airplay fails, I can’t connect from any device. To make it working again I have to go to settings => Services => Airplay: disable and enable it. Then it works again.
When it fails the effect is that it is visible in the airplay menu of the iphone/ipad/mac, I can select it, but I get an error: “unable to connect”.
Same effect with the 3 apple devices. All connected to the same wifi.
It’s Kodi 19.4 on a raspberry 4 (OMSC).
In kodi I have the option “Enable airplay videos and pictures” disabled in the airplay settings.
I have enabled the logs and watched it from a remote terminal with ‘tail -f’ while I try to connect. When it fails to connect nothing is shown in the logs, like it’s not receiving any connection request. So, there is nothing in the logs.
When I disable/enable airplay in kodi, it works again, and then I can see in the logs the process of connecting, sending the song picture, etc.
I have also a Marantz AVR with airplay enabled that works always fine, with the same apple devices sending the audio.
Any hint would be appreciated.
Thank you!
