Allo Digione add to OSMC for an ex Libreelec user
Hi newbie here, used to use Libreelec. Was able to add the card in that but can’t find where I’m supposed to add the line for overlay in osmc. mount -o remount,rw /flash was the command before but obviously /flash is not part of osmc
just wondering if someone can point me in the right direction.
You should be able to activate it via Settings → MyOSMC → PiConfig.
If that doesn’t work you can directly (no need to remount) add it to /boot/config-user.txt
That is fantastic, works now. Thanks for the quick reply and fix
Did it work via MyOSMC?
yes that’s how i did it. nice little control panel that is, thanks for your help.
