I need help to get OSMC working with Allo Digione. I did find an overlay for it here: firmware/boot/overlays at master · raspberrypi/firmware · GitHub but I don’t get it to work. Hopefully someone already solved this and can guide me in the right direction.
I understand that I should have been more specific to start with. It does not appear as an option and after manually adding the file to the overlay direction and configuring the config.txt it still doesn’t appear.
I have now tried Allo Digione on DietPi with Kodi and Digione works good but I really do prefer OSMC. I have added the .dtbo file to overlays and changed the config.txt. What do I have to do more to get it to work??
I can’t see the card if I type aplay -l btw so I must be doing something wrong with the overlays. Can someone please send a link to some similar problems because I’ve been looking but I don’t find any good info on how to proceed…
Hello all. I wanted to follow up on this post as I have a Digione on my pi and am trying to configure it to osmc. I too believe I have loaded the overlay and configured it but I do not see it as an option in any setting on the osmc software. I am hoping someone has an answer or will be willing to help. Thank you!
