osmc@vero4kp2:~$ speaker-test -c2 -t wav
speaker-test 1.2.4
Playback device is default
Stream parameters are 48000Hz, S16_LE, 2 channels
WAV file(s)
Rate set to 48000Hz (requested 48000Hz)
Buffer size range from 32 to 131072
Period size range from 16 to 16384
Using max buffer size 131072
Periods = 4
was set period_size = 16384
was set buffer_size = 131072
0 - Front Left
1 - Front Right
Time per period = 0.377738
0 - Front Left
1 - Front Right
Time per period = 3.067283
0 - Front Left
1 - Front Right
The first ‘Front Left’ is not complete but from then on it’s fine.
Vero’s chip supports only 2 or 8 channels. In Kodi we send 8 channels but mask the unused channels when playing 4 or 6 channels. Odd numbers of channels can be problematic. If playing directly through ALSA you may need some custom .conf files for channel counts other than 2 or 8.
I had a look at mpd and wondered why you want to use it. One of the joys of Kodi is I can run it on every device I have in the house from the same media server and with the same user interface. Is there some special thing mpd can do that we could add to OSMC?
