I’ve lost my Vero 4K remote! Well someone’s moved the thing and now it’s nowhere to be found.
Can I use a different remote somehow? For example I have a special remote for my TV that I ordered to get into the development settings of my TV. Any chance this would work? I can’t watch anything! Help!!!
Sorry to hear this.
It may work if your TV supports CEC. If it’s an IR remote, there is the potential to record button presses.
If you want another remote, send me a PM. I will send one at cost for you.
How about an app on your mobile phone?
The official Kodi app works well.
Thanks for the offer Sam. My TV is an LG E6 OLED. If I’m honest I think my girlfriends 6 year old nephew has picked it up whilst here and taken it for walkies. But she’s having none of it! Anyway I’ll have another hunt again over the weekend and get back to you.
I’ll have a look into this. I didn’t even know there was one!
I’m not sure what this means. Should I enable this?
I think … yes.
I assume that this is the setting in Kodi that allows full remote control.
However, if you have enabled external (outside access to your LAN) via port forwarding or similar then I would take extra care.
