My OSMC was working fine. But after an update is installed, Amazon prime video is not showing properly. Sound and subtitles are coming. But video screen is jumbled and filled with changing colours. No picture at all!
Please help
reproduce the issue
upload the log set (all configs and logs!) either using the
You probably need to update your Widevine version.
Its already updated
Then logs will be needed to provide any meaningful assistance.
Here are the logs :
https://paste.osmc.tv/owocifixej
Please go through and help
Pl. see the logs posted above
Pl see the uploaded logs.
I think, since you are the only person to have reported this issue, your first step should be to try a reinstall, possibly on another SDcard. Whatever has caused this issue is not a widespread problem affecting any other users.
OK. Thanks.
But after this problem started, I removed the SDCard, after it got physically damaged. Then I reinstalled OS on a new SDcard, from which it is running now. And the same problem continues!
I shall install in a new SD card and try again and shall post the results here. Thanks once again.
I don’t know anything about this add-on but I would probably turn off OMXPlayer and see if the issue goes away. I also noticed you had set framebuffers in your config.txt and I wonder if that could be related. That is not a setting you normally see manually set.
