Hello,
I’m trying for the first time Android on my Vero 2. I’m having toubles because after the dual boot I’m not able to use the remote. I cannot go into the setup so I cannot chang anything.
What can I do?
Android and Remote
Giubeca
#1
sam_nazarko
#2
Some apps will work with the remote and some won’t. You may need a keyboard or mouse for some apps
Hello… I’ve just started android image on Vero 2. How can I configure keyboard? I can just access menu with remote control, but can’t click anything. Is this image the latest android image: https://ftp.fau.de/osmc/osmc/download/installers/diskimages/OSMC_TGT_vero2_android_20160821.img.gz ? I found only one with substring android.
Thanks for the info
I have hard time getting into / finding Settings. How do you get there with remote control?
sam_nazarko
#6
Which launcher are you using? If you plan to use a keyboard, then attach the keyboard first
