Hello
Are there any Android Emulators I can run on Raspberry PI3 and OSMC ?
Hello
If you want Android and Kodi I think it would make more sense to install Android on your Pi and then install Kodi on Android.
Were can I find an Android install for RPI3B+ ?
I think support is dwindling for this arch
Thanks in advance
small suggestion, google knows alot
Using raspberry pi3B+ (armv7l).
Is virtualization turned on in this image OSMC_TGT_rbp2_20230606.img.gz ?
If so, are the VM libraries installed ?
Now it has been a while since i used OSMC on a pi device, last pi3 just stopped responding 8 months ago. but here goes a train of thoughts:
OSMC is a Debian based OS, optimised for mediacenter activities, is virtulization among those in your mind?
Do yuo belive a devie with just 1 gb of ram wil handle two graphical OS at the same time?
So even if debian has packages for it, why would they be distobuted as install by default on a mediacenter?
In my mind that is like takeing a kajcc to cross the Atlantic ocean, possible but not even close to enjoyable or as problem free as other alternatives.
Nice reply, thanks for the info.
