Last September, we announced that OSMC had teamed up with WDLabs, a business growth incubator division of Western Digital. We've stayed in touch since then and we've spent several months working on something that compliments Raspberry Pi and really allows our users to get the best of OSMC.
I, and I’m sure many others here, already have the 1TB PiDrive that was released some time ago; but a nicer case, such as this one, would be great compared to the wonky case that WDLabs built.
We don’t have plans to do so at this time, but I’ll keep this suggestion in mind. One reason I’m not quite sure about selling the case on its own is that the drive we ship with it is a good fit for the case (both size and heat wise). Other drives may not be. I understand that an existing PiDrive by WD will be fine, but this is a rare request.
I’d also just like the opportunity to buy the case plus the accessories minus the drive and the SD card. This would be a much nicer setup that what I currently use, but I would like to maintain my existing 1Tb drive. I assume this uses a standard 2.5" SATA drive.
As mentioned above, the exact height of the drive / power / heat requirements mean that some people may be disappointed if they use a third party. The drive is 7mm. You would also need a drive compatible with the PiDrive cable.
What is actually so special about this drive? Is it more secure (so it dosen’t break so easy), or is it only special because it can get inside the osmc case?
The kit does not include an IR sensor. TSOPs are quite cheap to buy and wire to the GPIO and our official, recommended remote uses a small USB RF sensor.
Does the PiDrive have enough space to fit a Hifiberry (or other brand) DAC? When I go for a portable system, I want to have analog ports (that do not have noise like the builtin version of the raspberry). I can create a hole for the ports myself, just need to know if the PiDrive case top will close.
