I’ve searched and found no answer - hope you can help.
Last night I started watching a video. After a couple of seconds, the screen went black, and I’ve not been able to get it back. TV thinks it is getting a signal.
System boots, and I can SSH
I’ve previously set up an edid.dat file (due to the OSMC not recognising TV at boot)
I have already tried renaming .kodi and rebooting.
Thanks for any help - tv services follow.
So:
tvservice -s
state 0x12000a [HDMI CEA (31) RGB lim 16:9], 1920x1080 @ 50.00Hz, progressive
osmc@osmc:~$ tvservice -m cea
Group CEA has 22 modes:
mode 1: 640x480 @ 60Hz 4:3, clock:25MHz progressive
mode 2: 720x480 @ 60Hz 4:3, clock:27MHz progressive
mode 3: 720x480 @ 60Hz 16:9, clock:27MHz progressive 3D:TopBot|SbS-HH
mode 4: 1280x720 @ 60Hz 16:9, clock:74MHz progressive 3D:FP|TopBot|SbS-HH
mode 5: 1920x1080 @ 60Hz 16:9, clock:74MHz interlaced 3D:FP|TopBot|SbS-HH
mode 7: 720x480 @ 60Hz 16:9, clock:27MHz x2 interlaced
mode 11: 720x480 @ 60Hz 16:9, clock:54MHz x4 interlaced
mode 15: 720x480 @ 60Hz 16:9, clock:54MHz x2 progressive
(native) mode 16: 1920x1080 @ 60Hz 16:9, clock:148MHz progressive 3D:TopBot|SbS-HH
mode 17: 720x576 @ 50Hz 4:3, clock:27MHz progressive
mode 18: 720x576 @ 50Hz 16:9, clock:27MHz progressive 3D:TopBot|SbS-HH
mode 19: 1280x720 @ 50Hz 16:9, clock:74MHz progressive 3D:FP|TopBot|SbS-HH
mode 20: 1920x1080 @ 50Hz 16:9, clock:74MHz interlaced 3D:FP|TopBot|SbS-HH
mode 22: 720x576 @ 50Hz 16:9, clock:27MHz x2 interlaced
mode 26: 720x576 @ 50Hz 16:9, clock:54MHz x4 interlaced
mode 30: 720x576 @ 50Hz 16:9, clock:54MHz x2 progressive
(prefer) mode 31: 1920x1080 @ 50Hz 16:9, clock:148MHz progressive 3D:TopBot|SbS-HH
mode 32: 1920x1080 @ 24Hz 16:9, clock:74MHz progressive 3D:FP|TopBot|SbS-HH
mode 33: 1920x1080 @ 25Hz 16:9, clock:74MHz progressive
mode 34: 1920x1080 @ 30Hz 16:9, clock:74MHz progressive
mode 36: 720x480 @ 60Hz 16:9, clock:108MHz x4 progressive
mode 38: 720x576 @ 50Hz 16:9, clock:108MHz x4 progressive
osmc@osmc:~$ tvservice -m dmt
Group DMT has 4 modes:
mode 4: 640x480 @ 60Hz 4:3, clock:25MHz progressive
mode 9: 800x600 @ 60Hz 4:3, clock:40MHz progressive
mode 16: 1024x768 @ 60Hz 4:3, clock:65MHz progressive
mode 35: 1280x1024 @ 60Hz 5:4, clock:108MHz progressive
