Any know issues with Vero V micro-freezing video on H265?
I have one Vero 5 setup and a couple of Vero 4K+ setups using the same source NAS and shared library over the same wired gigabit network. The V occassionally freeze frames the video (but not the audio) for a fraction of a second on high bitrate 4k/H265 MKVs. I don’t seem to see this on the 4K+ setups at all. It’s not reproducable either, so if I skip back and watch the section again it doesn’t freeze.
As close to a pattern as I can discern is that it happens on H265 where the bitrate is >90Mbs and there is a lot of action going on in the picture. …but as I say it’s not reproducable. It often happens in pairs, so it’ll do it a couple of time in a minute and then maybe not for 10 minutes.
Is this a known problem/are there other reports of it?
Haven’t seen anything reported here.
Are you watching on WiFi or Ethernet? Kodi v21 changed the buffering scheme a lot and we have made educated guesses about to handle it.
There are some borderline situations where this may not be correct.
I’m guessing the 4K+ and V aren’t in the same room, hence why I ask if WiFi is being used.
I’m sure we can solve it but will need a bit more info
Hi Sam,
Confirm as above, this is on a wired gigabit ethernet network. Note also that there is no disruption to audio playback, and it’s only the video that freezes (for a fraction of a second). As it’s intermittent and not repeatable it’s quite difficult to catch.
A log might give us some clues as to what is going on.
I’ll try and catch it if I can. and get back to you.
Apologies as still no logs, however FYI this is still ongoing and I’m now starting to see some wierd multi-coloured onscreen decode artifacts with my 4K material. HD and SD material seems unaffected. Could this be a hardware issue?
I doubt it. But anything is possible in life.
Do you have a small video sample that can reliably reproduce the problem?
A log for what plays without issue vs what does would be good. Then I can check the video format and if the HW decoder is engaged. For some SD material it won’t be engaged.
Sorry Sam. I can’t get it to reproduce. It seems entirely random.
Since new I’ve been using it with the OSMC POE adapter for power. I swapped it over to the bundled AC adapter last evening, and I’ve so far seen no futher freezes or artifacts. It’s early days for declaring a resolution however, given the sporadic and unpredictable nature. It might just be a temporary improvement based on a full power cycle and nothing to do with the power source.
Keep me posted
Hi Sam,
No further occurence since POE adapter replaced with power supply. My first thought is the POE adapter is faulty as the switch is also running a wireless AP seemingly without issue.
Have you tried swapping the port on the switch with the one used by the AP?
Have you checked that the switch PSU can power both at once?
