Hey, I would like to ask if there are any news on Bluetooth audio streaming? Topics regarding BT streaming are quite old…is there any progress? I would like to stream music from iPhone to Vero4k. I can pair Vero4k with iPhone, but I dont have possibility to select Vero, or anything other as a speaker in Music app, where it should be. So the sound goes always from phone.
Thanks.
If you install the A2DP package this should work.
@shiro35 I just tested, when you enable a2dp then it works fine
How do I install that A2DP package? Thanks.
sudo apt-get install a2dp-app-osmc
How do you install it without coding like that? Is there an app in the store that is the same?
Currently it is not in the app store.
But this is not really “coding” you just need to enter that line on the command line.
Details regarding how to access the command line interface can be found here on our Wiki: Accessing the command line - General - OSMC
Just installed A2DP and works okay with iPhone SE iOS 11.4.
