I’m using a apple remote (white) on a pi2 .
I’m also using a IPTV addon, i would like to know if it’s possible to set up the remote to allow the UP/Down key to change the channel next/previous and maybe LEFT/Right to managet the volume ?
Actually, if i want to change the channel, i have to press menu to go back to the channel list and then select the other channel.
Is it possible to change that and where ?
Thx.
