Thanks Sam, tried a 4th stick this morning… still just stuck with blinking orange light and no display… after 30 mins or more of waiting
Is it possible I could solve by removing HDD and attaching to a Linux PC and using DD? I notice there are two partitions (one with Apple format) and one with a big Tar file for OSMC in installer. Ideally I’d be able to restore the ATV OS itself if someone has a backup somewhere, then fix that RGH High and then put OSMC back on.
Whatever RGB was set as in the original firmware doesn’t matter since it is (properly) overridden by the Nvidia driver when running Linux anyways.
In xorg.cong you can change
COLORRANGE=limited (RGB HIGH) or COLORRANGE=full (RGB Low)
I don’t remember what the default setting is but I think it is RGB LOW. In all practicality that won’t matter since when the driver loads it will change metainfo in the HDMI stream and your TV will change accordingly.
It is but it doesnt matter. Maybe you didn’t know, but it can be set inside xorg.conf.
To be clear: Let’s say you have pink screen at startup, and you think you need to restore to atv os to change the hdmi output setting: well you don’t, it can be set inside xorg.xonf. You still get a few moments of pink screen at boot but once inside Kodi, it will be fine.
(The reason for the pink screen is that sometime when atv outputs YCC the TV somehow thinks it’s receiving RGB, and also sometimes it resets to this by itself even though you have chosen hdmi low or hdmi high in atv os settings. It seems the hdmi infoframes which tell the tv what colorspace the atv outputs, have some compatibility issues, at least with some tvs, until the driver is loaded)
Not sure if I understand you right… dunno about newer nvidia drivers in general (although I kinda refuse to believe you cant change the colorspace and range for the typical nvidia gpu in Linux), but this was just about the Apple TV and only that, including the latest 304.137 driver.
Maybe older philips tvs have problems at boot, but once inside Kodi even they will work fine, at least if you have defined the colorspace/colorrange inside xorg.conf.
