Hello,
I am using OSMC 2019.04-1 with the Skin Aeon MQ8 on a Raspberry Pi3. Unfortunately I have problems with my Harmony remote control, which worked fine until now (lircd-full). Since the April version I can’t find a way to open the context menu anymore. When pressing the menu key, the message “No PVR addon activated” always appears. Also the delete function doesn’t work anymore.
Using an USB-keyboard, I can easily call the context menu via “C” and execute the delete function via the Delete key. I tested all commands on the remote control - unfortunately without success. Does anyone have any advice for this problem?
Hi everybody, I’ve found the solution by now. With the addon “Keymap Editor” the keys can be easily and quickly reassigned. No programming necessary.
