Hi i get this error when i want to do a “apt-get update”
W: GPG error: http://apt.osmc.tv stretch InRelease: The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY 553B25A766C762CC
i then try:
wget [http://apt.osmc.tv/apt.key
gpg --import apt.key
gpg --send-keys 553B25A766C762CC
gpg --keyserver http://keys.gnupg.net --recv-key 553B25A766C762CC
gpg -a --export 553B25A766C762CC | apt-key add
but i get:
gpg: requesting key 66C762CC from http server keys.gnupg.net
gpgkeys: no key data found for http://keys.gnupg.net/
gpg: no valid OpenPGP data found.
gpg: Total number processed: 0
Any advice? (i want to update because i have a problem with the CEC, every time i turn on my AVR the source is automatic changed to OSMC (RPI2)
So, in summary:
activate the logging
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
Hmm i tried to update the cec-utils just to make sure it was up to date, and now i really can’t reproduce the issue. so maybe it is fixes, i will continue to test.
Thank you all for the help so far. Problem still persists.
This is from my openhab log:
2018-09-15 11:05:15.962 [INFO ] [runtime.busevents ] - DenonInput state updated to DVD
2018-09-15 11:05:15.995 [INFO ] [runtime.busevents ] - DenonPower state updated to ON
2018-09-15 11:05:16.019 [INFO ] [runtime.busevents ] - DenonInputDVD state updated to ON
2018-09-15 11:05:16.037 [INFO ] [runtime.busevents ] - DenonInputMplay state updated to OFF
2018-09-15 11:05:21.380 [INFO ] [runtime.busevents ] - DenonInput state updated to MPLAY
2018-09-15 11:05:21.403 [INFO ] [runtime.busevents ] - DenonInputMplay state updated to ON
2018-09-15 11:05:21.444 [INFO ] [runtime.busevents ] - DenonInputDVD state updated to OFF
2018-09-15 11:05:21.462 [INFO ] [runtime.busevents ] - DenonMainZone state updated to ON
I press the remote Source DVD and the Denon turns on, when it is powered on it changes to OSMC.
Suggest you open a new thread not to confuse with your apt key problem.
For CEC cec-utils don’t play a role so that wouldn’t have changed anything.
Did you disable “switch active source” in the CEC settings?
