Vero 4k runs Debian, and understands both
apt-get update & apt-get dist-upgrade
and their apt equivalents:
apt update & apt full-upgrade
I’ve used the latter on the 4k without any problems whatsoever.
Just a quick question about the differences between these two…
As in the help page I linked to above, all the way at the bottom of this page it advises to use “apt-get” rather than the (at least in Debian?) newer apt, I was wondering if there was a specific reason for this. I’m guessing it may have anything to do with cross-device compatibility?
On the Vero 4k, is there any difference between the two? Anything that gets done a different way? Is there a reason to prefer one over the other?
Thanks to anyone who can shed some light on this!
Cheers,
Maarten
There is no issues using apt over apt-get, just need to avoid using:
sudo apt upgrade
or
sudo apt-get upgrade
As this can cause breakages.
Thanks Tom.
Understood! Thanks, that fully answers my question.
APT CLI interface is not stable yet. Use apt-get
That is good to know!
I must admit I thought it was best practice to actually use apt rather than apt-get and I have been using it for months without any problems, but won’t be using it on the vero 4k in the future!
Thanks for clearing that up.
Nothing wrong with using apt, but I believe the interface is subject to change, so some learning could be required unexpectedly.
Got you
So that must be why in the website I referred to it is still said to use apt-get. I really was just curious. How is your response time this ridiculous, by the way
