Hello,
It seems that there is a conflict between OSMC & debian repo’s.
When I try to install “qtbase5-dev” package (distributed by debian repo), i cannot because of “rbp2-mesa-osmc”.
Here is the apt install log :
sudo apt install qtbase5-dev
Reading package lists… Done
Building dependency tree… Done
rbp2-mesa-osmc : Conflicts: libegl1
Conflicts: libgl1
Conflicts: libglx0
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
Here is the detailled content of the rpb2-mesa package :
apt show rbp2-mesa-osmc
Package: rbp2-mesa-osmc
Origin: OSMC
Version: 23.2.0-2
Essential: No
Maintainer: Sam G Nazarko email@samnazarko.co.uk
Priority: optional
Section: libs
Filename: pool/main/r/rbp2-mesa-osmc/rbp2-mesa-osmc_23.2.0-2_armhf.deb
SHA256: 5133fffa62b4e9756a914194eef225eadf6c68c5c11c8bf2852344de24bb59cb
SHA1: a38a0e5b03c826408e7b813d74c1aa129c855042
MD5sum: 4982d4c28483724ac5bb0bcdf2ce2ae7
Description: MESA graphical libraries for OSMC
Description-md5: 66b7638fc0e5ca807255962445b869ea
Depends: libexpat1, zlib1g
Provides: libegl-mesa0, libegl1, libgl1, libgl1-mesa-dri, libglapi-mesa, libglx-mesa0, libglx0
Replaces: libegl-mesa0, libegl1, libgl1, libgl1-mesa-dri, libglapi-mesa, libglx-mesa0, libglx0
Conflicts: libegl-mesa0, libegl1, libgl1, libgl1-mesa-dri, libglapi-mesa, libglx-mesa0, libglx0
Architecture: armhf
Installed-Size: 10337
And qtbase5-dev one :
sudo apt show qtbase5-dev
Package: qtbase5-dev
Source: qtbase-opensource-src
Version: 5.15.2+dfsg-9
Installed-Size: 14416
Maintainer: Debian Qt/KDE Maintainers debian-qt-kde@lists.debian.org
Architecture: armhf
Replaces: qt5-qmake (<< 5.11.3+dfsg-3~), qtbase5-dev-tools (<< 5.12.5+dfsg-3~), qtbase5-private-dev (<< 5.11.3+dfsg-5~)
Depends: libegl-dev, libgles-dev, libqt5concurrent5 (= 5.15.2+dfsg-9), libqt5core5a (= 5.15.2+dfsg-9), libqt5dbus5 (= 5.15.2+dfsg-9), libqt5gui5 (= 5.15.2+dfsg-9), libqt5network5 (= 5.15.2+dfsg-9), libqt5printsupport5 (= 5.15.2+dfsg-9), libqt5sql5 (= 5.15.2+dfsg-9), libqt5test5 (= 5.15.2+dfsg-9), libqt5widgets5 (= 5.15.2+dfsg-9), libqt5xml5 (= 5.15.2+dfsg-9), libvulkan-dev, libxext-dev, qt5-qmake (= 5.15.2+dfsg-9), qtbase5-dev-tools (= 5.15.2+dfsg-9), qtchooser
Recommends: libqt5opengl5-dev (= 5.15.2+dfsg-9)
Suggests: default-libmysqlclient-dev, firebird-dev, libpq-dev, libsqlite3-dev, unixodbc-dev
Conflicts: qtbase5-gles-dev
Breaks: qt5-default (<< 5.15.1+dfsg-2~), qt5-qmake (<< 5.11.3+dfsg-3~), qtbase5-dev-tools (<< 5.12.5+dfsg-3~), qtbase5-private-dev (<< 5.11.3+dfsg-5~)
Description-en: Qt 5 base development files
Qt is a cross-platform C++ application framework. Qt’s primary feature
is its rich set of widgets that provide standard GUI functionality.
This package contains the header development files used for building Qt 5
applications.
If you are interested in packaging Qt 5 stuff please take a look at
The Debian KDE maintainers website
Description-md5: eb1a5e244bfc7327cfdf56f6aff9cab9
Multi-Arch: same
Homepage: For developers | Cross-platform development
Tag: devel::lang:c++, devel::library, role::devel-lib
Section: libdevel
Priority: optional
Filename: pool/main/q/qtbase-opensource-src/qtbase5-dev_5.15.2+dfsg-9_armhf.deb
MD5sum: 89707fe4b629323c2a1a2e8a4a8cb271
SHA256: f859f342306d4a8dcbe45664668c40cb1f065c971bdf15eb90071192d1ce7a74
Do you think you can do something?
Regards
