It’s the same url with end
acakayogot
Please run a command from the command line and show us the output.
sudo apt-get update
If there is no error from the update command, please also run:
sudo apt-get dist-upgrade
Thanks for the answer…
I am a beginner…
how to execute the command line
Hello,
I did the manipulation with Putty and after having launched the 2 commands I get this at the end :
The following package disappeared from your system as
all files have been overwritten by other packages:
vero3-libamcodec-osmc
Note: This is done automatically and on purpose by dpkg.
It’s OK ?
Hello,
after the manipulation with Putty, I turned on VERO and the Kodi screen appears with
“database migration…”
It has been 20 minutes now…is this normal?
Depending on the size of your database, it can take a while for the migration to complete. So yes, that is normal.
Thank’s
That is correct. It has been replaced by the package libamcodec-osmc.
Thanks for the encouraging answer…
I now have a problem of slowness since the update…
First at startup, the Vero splash arrives late…then when I update the movie library…
Please open a new thread with details of your problem and provide full debug logs.
reproduce the issue
upload the log set (all configs and logs!) either using the
Hi Sam,
I must be unlucky. I have 4 Vero setups and I needed the hotfix for 3 of them.
Best regards,
Mark W.
Did you buy those three at the same time / close together?
In three separate batches from recollection; an older 4K, a 4K+ for testing, then a further 2x 4K+.
From what I can see, a lot of Debian systems were messed up by these changes and it’s going to be an issue for a lot of users that haven’t updated for a while.
Fortunately, we have a simple solution.
I ran into the same issue on a 4K+, applied the hotfix and it worked fine.
Former version: November 2020 2020.11-1
Many thanks
I know its a bit old hat now but just to confirm this solution worked for me too. I hadn’t upgraded for a while as I thought this would be automatic? Logged into Putty, ran the update command and it did a few things but rebooting didn’t get the new OSMC upgrade or Kodi 19.1. So ran the hotfix command back in the first few posts then ran the manual updater and it started to run the upgrade. Bingo!
Thank god for forums like this
Unless you disabled it it will automatically show you a message when a new update is available.
Sorry to bump this thread. But I encountered this “oldstable” error/warning and went through and did sudo apt-get dist-upgrade anyway. I now have myself an OSMC that shows a sad face and does not seem to want to do anything else.
My question is how can I apply the hotfix from the command line (since I don’t have access to OSMC UI anymore)
Thx.
[Update] I’ve rubber duck debugged myself.
Running sudo apt-get update --allow-releaseinfo-change got me out of this hole.
