Hi there,
OSMC used to work well on my raspberry pi2. Then the “sudo apt update && sudo apt upgrade” command couldn’t be finished without errors. So OSMC is still working but I am not able to update the system.
How can I fix this issue so that I am able to update that machine?
I pasted the output of apt upgrade below. You can find all logs here: https://paste.osmc.tv/jicewogave
Thanks for your help!
Christian
$ sudo apt upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
rbp2-image-4.9.29-10-osmc
The following packages have been kept back:
rbp2-device-osmc
armv7-libsqlite-osmc armv7-network-osmc armv7-splash-osmc base-files-osmc
bind9-host curl git git-man gnupg gpgv libavcodec56 libavfilter5
libavformat56 libavresample2 libavutil54 libbind9-90 libcurl3
libcurl3-gnutls libdns100 libisc95 libisccc90 libisccfg90 liblwres90
libmysqlclient18 libsmbclient libswscale3 libwbclient0 libxml2
linux-libc-dev mediacenter-addon-osmc mysql-common perl perl-base
perl-modules rbp-bootloader-osmc rbp-userland-osmc rbp2-kernel-osmc
rbp2-mediacenter-osmc samba-common samba-libs tzdata wget wpasupplicant
43 upgraded, 1 newly installed, 0 to remove and 1 not upgraded.
Need to get 0 B/95.1 MB of archives.
After this operation, 68.4 MB of additional disk space will be used.
Do you want to continue? [Y/n]
Extracting templates from packages: 100%
Preconfiguring packages ...
dpkg: error processing archive /var/cache/apt/archives/perl_5.20.2-3+deb8u9_armhf.deb (--unpack):
subprocess dpkg-deb --control was killed by signal (Segmentation fault)
dpkg: error processing archive /var/cache/apt/archives/perl-base_5.20.2-3+deb8u9_armhf.deb (--unpack):
