I am new, I apologize but I didn’t understand how use the template this forum is a bit complicated for me, I would ask a question if I can…
After cloned and mounted root on external hard drive I would update the system with aptitude instead apt and it broke the system so I had installing again OSMC, fine.
The question is: is it safe making updating with APT for the RPI2 installed by the image or if preferable I give up to do any update?
Hi, just a quick reply I upgraded with the command “aptitude safe-upgrade” but it downloaded the new kernel (4.x.x.) and, as I read there is not the initramfs tools, after the upgrading the system was not able to load the modules and thus booting.
How apt-get upgrade and aptitude safe-upgrade are quite similar how can I be sure that using apt instead aptitude I am not going to have the same issue?
