TV Recordings won’t play since the Kodi 18 update - everything was fine before. Just gives a sad face then restarts the PVR manager.
The files play correctly through the video menu, just not via TV menu.
No problem via Kodi on Win10, everything else on the Vero seems fine.
Logs at https://paste.osmc.tv/yiyusoconu
Looks a bit suspicious around Apr 26 18:51:11 and Apr 26 18:58:35
Resurrecting this as it still doesn’t work.
Does no one have a functioning Vero/ArgusTV or is it just me?
this PVR client is a non-offical kodi addon; nevertheless there is a kodi forum for this at Kodi Community Forum - Argus TV where member ksooo seems to try to keep this working as long as possible.
We could have a quick look into the logs but no guarantee to see anything helpful, for this follow the instructions below:
reproduce the issue
upload the log set either using the Log Uploader
method within the My OSMC menu in the GUI or the ssh
method invoking command grab-logs -A
