Full debug log https://paste.osmc.tv/wihukimiri
With HW decoding enabled showing artifacts and SW decoding enabled working as expected.
Had to take a picture of the TV as taking a screenshot in Kodi don’t show the artifacts.
While I don’t think it’s at all likely to be the cause of your immediate problem, this is an odd combination:
Force RGB output: false
Use limited colour range (16-235): false
Normally if the output is not RGB you would expect it to be “limited” rather than “full”.
This is a known bug. You can avoid it by trying different zoom settings. Or else…
Hopefully the issue is now addressed:
I also recommend you remove /etc/apt/sources.list.d/osmc-devel.list after updating.
This will deactivate the staging repository. You can do so with the following command:
sudo rm /etc/apt/sources.list.d/osmc-devel.list.
Ok.
