I installed the device in RPI 2 B, Kodi recogniced properly de device and everything seemed ok, but found this issue when I ran alsamixer:
Front slider-> ok
Rear slider-> manage central speaker.
Central slider-> manage rear left speaker.
Subwofer slider-> manage rear right speaker.
On the other side, speaker-test work fine, every speaker sounds with its correct name, these are some outputs.
osmc@pi2:~$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: ALSA [bcm2835 ALSA], device 0: bcm2835 ALSA [bcm2835 ALSA]
Subdevices: 7/7
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 IEC958/HDMI [bcm2835 IEC958/HDMI]
Subdevices: 1/1
card 0: ALSA [bcm2835 ALSA], device 2: bcm2835 IEC958/HDMI1 [bcm2835 IEC958/HDMI1]
Subdevices: 1/1
card 1: U5 [ASUS XONAR U5], device 0: USB Audio [USB Audio]
Subdevices: 1/1
card 1: U5 [ASUS XONAR U5], device 1: USB Audio [USB Audio #1]
Subdevices: 1/1
card 1: U5 [ASUS XONAR U5], device 2: USB Audio [USB Audio #2]
Subdevices: 1/1
osmc@pi2:~$ aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
default:CARD=ALSA
bcm2835 ALSA, bcm2835 ALSA
Default Audio Device
sysdefault:CARD=ALSA
dmix:CARD=ALSA,DEV=0
Direct sample mixing device
dmix:CARD=ALSA,DEV=1
bcm2835 ALSA, bcm2835 IEC958/HDMI
dmix:CARD=ALSA,DEV=2
bcm2835 ALSA, bcm2835 IEC958/HDMI1
dsnoop:CARD=ALSA,DEV=0
Direct sample snooping device
dsnoop:CARD=ALSA,DEV=1
dsnoop:CARD=ALSA,DEV=2
hw:CARD=ALSA,DEV=0
Direct hardware device without any conversions
hw:CARD=ALSA,DEV=1
hw:CARD=ALSA,DEV=2
plughw:CARD=ALSA,DEV=0
Hardware device with all software conversions
plughw:CARD=ALSA,DEV=1
plughw:CARD=ALSA,DEV=2
default:CARD=U5
ASUS XONAR U5, USB Audio
sysdefault:CARD=U5
front:CARD=U5,DEV=0
Front speakers
surround21:CARD=U5,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=U5,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=U5,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=U5,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=U5,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=U5,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=U5,DEV=0
IEC958 (S/PDIF) Digital Audio Output
dmix:CARD=U5,DEV=0
dmix:CARD=U5,DEV=1
ASUS XONAR U5, USB Audio #1
dmix:CARD=U5,DEV=2
ASUS XONAR U5, USB Audio #2
dsnoop:CARD=U5,DEV=0
dsnoop:CARD=U5,DEV=1
dsnoop:CARD=U5,DEV=2
hw:CARD=U5,DEV=0
hw:CARD=U5,DEV=1
hw:CARD=U5,DEV=2
plughw:CARD=U5,DEV=0
plughw:CARD=U5,DEV=1
plughw:CARD=U5,DEV=2
Is there any way to configure alsamixer to work properly?
Thanks in advance.
