@dastrix I didn’t think about it, but my Yamaha also has this setting. On mine, it’s not available on the OSD menu, it’s only available from the front panel buttons. Look in your owners manual to see if it has that setting and how to access it.
hi Sam
have you had a look at the logs I provided?
My 4K mode was already setup to Mode 1
thanks
Does this happen when connected directly to the TV?
Just trying to rule out Yamaha as a test
It hasn’t appeared to, no.
I think it may be worth looking at the Yamaha settings as suggested above then
As mentioned above ive already done that.
I’d then suggest waiting for an update. However if others aren’t experiencing problems with this receiver then something else is likely at play
As a test, have you tried with 4K set to Mode 2? Does your Yamaha have ‘passthrough’ that sends the HDMI signal untouched when the AVR is turned off? If so do you see the problem when the Yamaha is off?
