We wait impatiently.
TrueHD bitstreaming can cause audio to cut out briefly on high bitrate Atmos str…
Anyone else got any ideas re: Kodi not waiting long enough for disks to spin up?
Give the playlisttimeout a try see https://kodi.wiki/view/Advancedsettings.xml#playlisttimeout .
Set it in the /home/osmc/.kodi/userdata/advancedsettings.xml
, so it will not overwritten by the next update, You have to set it for the musiclibrary and videolibrary element separately
<videolibrary>
<playlisttimeout>60</playlisttimeout>
</videolibrary>
<musiclibrary>
</musiclibrary>
I will give that a try. Does that affect Plex Kodi Connect/Plex plugins etc? Because that’s why I use.
Thank you.
I don’t know, just give it try.
Will do, and will report back. Thanks.
If @JimKnopf’s suggestion doesn’t work, we’re going to need debug logs, along with timings for each action so we can relate them to the log.
WilliamG:Anyone else got any ideas re: Kodi not waiting long enough for disks to spin up?
Can you explain exactly what I need to do there?
Thanks.
Log Uploader
method within the My OSMC menu in the GUI or the ssh
method invoking command grab-logs -A
Perfect. Thank you. Will hopefully get to it later today.
Not yet — there won’t be another round of audio improvements for a little while yet
Hi Sam,
Another movie with Atmos dropouts, sadly: The Incredibles UHD. I could have sworn there was two places where it happened, but I was dozing off and can’t be sure.
However, one place where it DEFINITELY happens is at 1:02:30, when Mr. Incredible is running across a bridge-type structure. When the movie was done, I went back and repeated the glitch several times in the exact same place.
Also, if you look at my screenshot, - when it happens, the Atmos track is at around 10.5Mbits…
This is rendering a lot of the recent Disney movies a bit of a nuisance to watch…
Don’t worry – we’re working on this.
I’m getting closer to a solution
I’m getting closer to a solutionSam
Fantastic. I can’t wait.
Hey Sam, how goes the Atmos >10Mbit issue? Cheers.
I’m currently on holiday, so won’t be looking at this again until 13th July. I’m working on a couple of other issues when I get a minute, but I don’t have the equipment out here.
I need to test potential solutions on a few receivers, so it may take a small bit of time.
HOLIDAY? WHAT IS THIS MADNESS?!
Let me know if I can test anything for you. I have a Denon X4300H and a Sony HT-ST5000 (both Atmos), and two Vero 4Ks.
Enjoy your hols!
Also, Sam, is this of use?
No – we don’t use LAV. I believe someone else also raised this elsewhere and I gave a more detailed explanation.
I must have missed that. Bottom line is that it’s fixable, though?
We need to work out the exact problem first, but I am sure we will be able to do so shortly
