We were just having a small debate about this. Since we didn’t write the add-ons, it’s difficult to say. Plus, curl is able to access a wider range of URI “schemes” than just http and ftp, so it’ll be down to how it’s been coded deep inside Kodi and in the add-ons.
I’d suggest you just try it. If it doesn’t work, you’ve lost nothing.
Nope. Went to my Vero 4K today to try and fire up the latest Pirates of the Caribbean UHD, and got the dreaded message “One or more items failed to play.” Had to hit OK again, and it fired up.
Any other ideas?
Also, then encountered the dreaded Dolby Atmos drop-outs around 17:45-19:00. So double issues today, both of which appears to not be “directly” the Vero 4K’s fault!
Well generally any addons, Kodi base functions or external applications are best supported in the respective forum.
Any playback issue that is related to the hardware or underlying OS are best taken care here.
But surely often enough there are also people around here who have ideas on other topics.
Sure thing. I suspect this issue will get more and more prevalent with Disney movies like these trouble ones with high-bitrate Atmos tracks. Definitely annoying!
