The atmos track on POTC Dead Men Tell No Tales and some other films have sound drop outs with the Vero - I think it may be a Kodi issue according to this:
https://forum.kodi.tv/showthread.php?tid=327153
The Realtek chip doesn’t have these dropouts. Is this something that can be looked at?
Why double post?
The audio dropouts may be to do with the bitrate of the atmos track - the Vero has problems with the POTC dead men tell no tales atmos track due to the bitrate and had several audio dropouts.
Have a look at this:
There are some playback improvements for 4K HEVC content which should hopefully fix issues where the decoder would get stuck. An example of this is John Wick 2, where there is a very specific freeze.
The issue should now be fixed, but we need to get some testing to ensure that other HEVC content also behaves as expected.
I’d appreciate it if you could test this and provide feedback before we release this as an update to other users. To test this update:
Login via the command line
Edit th…
It might be an issue related to UHD playback with several titles which is being worked on in the above thread.
