I have the following observed during installation.
new fresh installation with the Image OSMC_TGT_appletv_20160130-HDD.img.gz
Unlike a fresh installation with the Image OSMC_TGT_appletv_20160118-HDD.img.gz comes here not prompt to remove the USB stick and the power cord and restart without USB stick.
Where after the installation is performed on the hard disk by following.
In the case with the image OSMC_TGT_appletv_20160130-HDD.img.gz he starts the installation directly on the USB stick and not on the hard disk.
I think that’s the problem, you can ask the inspected and repaired.
I have the same issue withe the Apple TV install. I downloaded the newest installer from osmc.tv, and noticed that I could only select the install option “on an SD card”. I could not select the other options. This was the case on my last install also, just went on and all seemed fine.
Right guys correct me if you think I’m wrong, Firstly what happens when you insert your Flash Drive, it says “Formatting Device”, then it goes on to say “Installing Files”, now the ones like myself see the box stuck on the words “Installing Files”, after waiting about ten minutes we take out the Flash Drive and reboot the box, to find the previous Good HD Install still on the box, Good you all say, but wait a minute guys, remember the first think you read, yes,** “Formatting Device”** so will you all agree with me that there lies the problem, the format is not working, because if it was the install files would work, and also we would have lost all our previous HD installs, but the fact that my old install still works proves it.** “THE FORMATTING DEVICE”** command does not work.
lør. 30. jan 21:49:19 2016 Could not load translation!
lør. 30. jan 21:49:19 2016 Resolving a mirror
lør. 30. jan 21:49:19 2016 Resolved mirror to Index of /sites/edge.samnazarko.co.uk/osmc/download
lør. 30. jan 21:49:19 2016 Enumerating supported devices
lør. 30. jan 21:49:19 2016 Added the following devices
lør. 30. jan 21:49:19 2016 Vero
lør. 30. jan 21:49:19 2016 Raspberry Pi 1 / Zero
lør. 30. jan 21:49:19 2016 Raspberry Pi 2
lør. 30. jan 21:49:19 2016 Apple TV
lør. 30. jan 21:49:19 2016 Checking for updates
lør. 30. jan 21:49:19 2016 Checking for updates by downloading http://mirrorservice.org/sites/edge.samnazarko.co.uk/osmc/download//installers/latest_windows
lør. 30. jan 21:49:19 2016 Acquired mirror file
lør. 30. jan 21:49:19 2016 No new update is available
lør. 30. jan 21:49:23 2016 The user has selected English as their language
lør. 30. jan 21:49:23 2016 The user has selected Apple TV as their device
lør. 30. jan 21:49:23 2016 Attempting to download device versions file http://mirrorservice.org/sites/edge.samnazarko.co.uk/osmc/download/installers/versions_appletv
lør. 30. jan 21:49:24 2016 Found a build called 2016.01-1-USB
lør. 30. jan 21:49:24 2016 Found a build called 2016.01-1-HDD
lør. 30. jan 21:49:24 2016 Found a build called 2015.12-4-USB
lør. 30. jan 21:49:24 2016 Found a build called 2015.12-4-HDD
lør. 30. jan 21:49:24 2016 Found a build called 2015.10-2-USB
lør. 30. jan 21:49:28 2016 The user has selected an online image for Apple TV with build URL : http://mirrorservice.org/sites/edge.samnazarko.co.uk/osmc/download/installers/diskimages/OSMC_TGT_appletv_20160130-USB.img.gz
Tried it again now, and now it gets the hdd build when selected.
søn. 31. jan 13:50:01 2016 Could not load translation!
søn. 31. jan 13:50:01 2016 Resolving a mirror
søn. 31. jan 13:50:01 2016 Resolved mirror to Index of /osmc/osmc/download/
søn. 31. jan 13:50:01 2016 Enumerating supported devices
søn. 31. jan 13:50:01 2016 Added the following devices
søn. 31. jan 13:50:01 2016 Vero
søn. 31. jan 13:50:01 2016 Raspberry Pi 1 / Zero
søn. 31. jan 13:50:01 2016 Raspberry Pi 2
søn. 31. jan 13:50:01 2016 Apple TV
søn. 31. jan 13:50:01 2016 Checking for updates
søn. 31. jan 13:50:01 2016 Checking for updates by downloading http://mirror.zetup.net/osmc/osmc/download//installers/latest_windows
søn. 31. jan 13:50:01 2016 Acquired mirror file
søn. 31. jan 13:50:01 2016 No new update is available
søn. 31. jan 13:50:06 2016 The user has selected English as their language
søn. 31. jan 13:50:06 2016 The user has selected Apple TV as their device
søn. 31. jan 13:50:06 2016 Attempting to download device versions file http://mirror.zetup.net/osmc/osmc/download/installers/versions_appletv
søn. 31. jan 13:50:06 2016 Found a build called 2016.01-1-USB
søn. 31. jan 13:50:06 2016 Found a build called 2016.01-1-HDD
søn. 31. jan 13:50:06 2016 Found a build called 2015.12-4-USB
søn. 31. jan 13:50:06 2016 Found a build called 2015.12-4-HDD
søn. 31. jan 13:50:06 2016 Found a build called 2015.10-2-USB
søn. 31. jan 13:50:12 2016 The user has selected an online image for Apple TV with build URL : http://mirror.zetup.net/osmc/osmc/download/installers/diskimages/OSMC_TGT_appletv_20160130-HDD.img.gz
Have not tried installing with the latest hdd build today. Last night when tried, it would halt at the full installing files bar.
