ATV1 USB Tuner not found
Hi Sam
great work !!
having been a loyal CB then CB2 fan (along with most of my immediate family and extended family)
-Being quite anxious to revive the ATV1- as I am off on Christmas Holidays - I thought I would give a try to the copy the image to a HDD then place said HDD in apple tv method
  1. downloaded apple HDD image to windows home computer
  2. unzipped said HDD image with win rar
  3. utilized a USB hard drive caddy
  4. targeted unzipped image to USB hard drive caddy with the HDD I intend to install in apple
  5. used the Win32DiskImager program to accomplish this task
  6. with the windows computer software selected “eject” the USB HDD caddy
  7. installed the HDD into the apple TV - powered up - presto :smile:
  8. worked perfect - went to my osmc - updates - manually pushed for updates
  9. plugged in a 4 port USB - powered hub
  10. plugged in a ORICO BTA-403 bluetooth adapter
  11. went to my osmc - networking -selected the bluetooth - paired my PS BD remote - it poped up - paired - again- presto - my PS3 BD blue tooth remote remote works perfect :smile
  12. went to my osmc - app store - installed TV headend server / SMB server / cron job scheduler
  13. once installed - rebooted
  14. went to my home computer - in the address line of a browser - osmc:9981 - presto tvheadend :smile:
  15. I am able to see my HD Homerun tuners - however i wish to use USB tuners
  16. plugged into my HUB a WinTV-HVR-950Q as well as a KworldUB435-Q V3
  17. SSH’d into the apple ran the command “lsusb”
  18. here is the output:
osmc@osmc:~$ lsusb
Bus 002 Device 006: ID 05ac:8241 Apple, Inc. Built-in IR Receiver
Bus 002 Device 030: ID 1b80:e34c Afatech
Bus 002 Device 029: ID 2040:7200 Hauppauge
Bus 002 Device 023: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (
Bus 002 Device 019: ID 05e3:0606 Genesys Logic, Inc. USB 2.0 Hub / D-Link DUB-H4
Bus 002 Device 018: ID 05e3:0606 Genesys Logic, Inc. USB 2.0 Hub / D-Link DUB-H4
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  1. looks good so far as device 030 is the 435-Q tuner and device 029 is the 950Q tuner
  2. then ran the command “dmesg | grep dvb” … nothing no response
  3. this is whereI am stuck - I am guessing the firmware for the 2 USB ATSC tuners is not loaded ?
I was on a roll - any help to finsh this off would be greatly appreciated
kindest regards
Post your complete dmesg/system journal
2 posts were merged into an existing topic: Hard disk installations now possible (Sorry, Coming Soon)
hi fzinken
really appreciate the quick reply
posted is the lsusb
posted is the full dmesg
osmc@osmc:~$ lsusb
Bus 002 Device 003: ID 05ac:8241 Apple, Inc. Built-in IR Receiver
Bus 002 Device 007: ID 1b80:e34c Afatech
Bus 002 Device 006: ID 2040:7200 Hauppauge
Bus 002 Device 005: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (        HCI mode)
Bus 002 Device 004: ID 05e3:0606 Genesys Logic, Inc. USB 2.0 Hub / D-Link DUB-H4        USB 2.0 Hub
Bus 002 Device 002: ID 05e3:0606 Genesys Logic, Inc. USB 2.0 Hub / D-Link DUB-H4        USB 2.0 Hub
osmc@osmc:~$ dmesg
[    0.000000] Linux version 4.2.3-6-osmc (root@compiler2) (gcc version 4.9.2 (D        ebian 4.9.2-10) ) #1 Mon Nov 2 17:21:18 UTC 2015
[    0.000000] Disabled fast string operations
[    0.000000] x86/fpu: Legacy x87 FPU detected.
[    0.000000] x86/fpu: Using 'lazy' FPU context switches.
[    0.000000] e820: BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000008efff] usable
[    0.000000] BIOS-e820: [mem 0x000000000008f000-0x000000000008ffff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x0000000000090000-0x000000000009ffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000bffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000025adfff] usable
[    0.000000] BIOS-e820: [mem 0x00000000025e7000-0x0000000002637fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000002638000-0x000000000f170fff] usable
[    0.000000] BIOS-e820: [mem 0x000000000f171000-0x000000000f371fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x000000000f372000-0x000000000febcfff] usable
[    0.000000] BIOS-e820: [mem 0x000000000febd000-0x000000000febefff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x000000000febf000-0x000000000febffff] ACPI data
[    0.000000] BIOS-e820: [mem 0x000000000fec0000-0x000000000feeefff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x000000000feef000-0x000000000fef0fff] usable
[    0.000000] BIOS-e820: [mem 0x000000000fef1000-0x000000000fefefff] ACPI data
[    0.000000] BIOS-e820: [mem 0x000000000feff000-0x000000000fefffff] usable
[    0.000000] BIOS-e820: [mem 0x000000000ff00000-0x000000000fffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000f00f8000-0x00000000f00f8fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fffa0000-0x00000000fffcffff] reserved
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] SMBIOS 2.4 present.
[    0.000000] DMI: Apple Inc. AppleTV1,1/Mac-F4228DC8, BIOS    ATV11.88Z.00DA.B        04.0912220919 12/22/09
[    0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000000] e820: last_pfn = 0xff00 max_arch_pfn = 0x1000000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-BFFFF uncachable
[    0.000000]   C0000-CFFFF write-protect
[    0.000000]   D0000-DFFFF uncachable
[    0.000000]   E0000-FFFFF write-protect
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 0FFE00000 mask FFFE00000 write-protect
[    0.000000]   1 base 000000000 mask FF0000000 write-back
[    0.000000]   2 base 00FF00000 mask FFFF00000 uncachable
[    0.000000]   3 disabled
[    0.000000]   4 disabled
[    0.000000]   5 disabled
[    0.000000]   6 disabled
[    0.000000]   7 disabled
[    0.000000] x86/PAT: PAT not supported by CPU.
[    0.000000] initial memory mapped: [mem 0x00000000-0x01ffffff]
[    0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[    0.000000] init_memory_mapping: [mem 0x00000000-0x000fffff]
[    0.000000]  [mem 0x00000000-0x000fffff] page 4k
[    0.000000] init_memory_mapping: [mem 0x0fc00000-0x0fdfffff]
[    0.000000]  [mem 0x0fc00000-0x0fdfffff] page 2M
[    0.000000] init_memory_mapping: [mem 0x00100000-0x025adfff]
[    0.000000]  [mem 0x00100000-0x001fffff] page 4k
[    0.000000]  [mem 0x00200000-0x023fffff] page 2M
[    0.000000]  [mem 0x02400000-0x025adfff] page 4k
[    0.000000] init_memory_mapping: [mem 0x02638000-0x0f170fff]
[    0.000000]  [mem 0x02638000-0x027fffff] page 4k
[    0.000000]  [mem 0x02800000-0x0effffff] page 2M
[    0.000000]  [mem 0x0f000000-0x0f170fff] page 4k
[    0.000000] BRK [0x01a8a000, 0x01a8afff] PGTABLE
[    0.000000] BRK [0x01a8b000, 0x01a8bfff] PGTABLE
[    0.000000] init_memory_mapping: [mem 0x0f372000-0x0fbfffff]
[    0.000000]  [mem 0x0f372000-0x0f3fffff] page 4k
[    0.000000]  [mem 0x0f400000-0x0fbfffff] page 2M
[    0.000000] BRK [0x01a8c000, 0x01a8cfff] PGTABLE
[    0.000000] init_memory_mapping: [mem 0x0fe00000-0x0febcfff]
[    0.000000]  [mem 0x0fe00000-0x0febcfff] page 4k
[    0.000000] BRK [0x01a8d000, 0x01a8dfff] PGTABLE
[    0.000000] init_memory_mapping: [mem 0x0feef000-0x0fef0fff]
[    0.000000]  [mem 0x0feef000-0x0fef0fff] page 4k
[    0.000000] init_memory_mapping: [mem 0x0feff000-0x0fefffff]
[    0.000000]  [mem 0x0feff000-0x0fefffff] page 4k
[    0.000000] BRK [0x01a8e000, 0x01a8efff] PGTABLE
[    0.000000] ACPI: Early table checksum verification disabled
[    0.000000] ACPI: RSDP 0x00000000000F8000 000024 (v02 APPLE )
[    0.000000] ACPI: XSDT 0x000000000FEFD1C0 000064 (v01 APPLE  Apple00  000000D        A      01000013)
[    0.000000] ACPI: FACP 0x000000000FEFB000 0000F4 (v03 APPLE  Apple00  000000D        A Loki 0000005F)
[    0.000000] ACPI: DSDT 0x000000000FEF4000 002BE5 (v01 APPLE  AppleTV  0001000        1 INTL 20050309)
[    0.000000] ACPI: FACS 0x000000000FEC0000 000040
[    0.000000] ACPI: HPET 0x000000000FEFA000 000038 (v01 APPLE  Apple00  0000000        1 Loki 0000005F)
[    0.000000] ACPI: APIC 0x000000000FEF9000 000068 (v01 APPLE  Apple00  0000000        1 Loki 0000005F)
[    0.000000] ACPI: MCFG 0x000000000FEF8000 00003C (v01 APPLE  Apple00  0000000        1 Loki 0000005F)
[    0.000000] ACPI: ASF! 0x000000000FEF7000 0000A0 (v32 APPLE  Apple00  0000000        1 Loki 0000005F)
[    0.000000] ACPI: SSDT 0x000000000FEF2000 0001A6 (v01 APPLE  Cpu0Ist  0000300        0 INTL 20050309)
[    0.000000] ACPI: SSDT 0x000000000FEF3000 000158 (v01 APPLE  Cpu0Cst  0000300        1 INTL 20050309)
[    0.000000] ACPI: SSDT 0x000000000FEF1000 0004DC (v01 APPLE  CpuPm    0000300        0 INTL 20050309)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] 0MB HIGHMEM available.
[    0.000000] 255MB LOWMEM available.
[    0.000000]   mapped low ram: 0 - 0ff00000
[    0.000000]   low ram: 0 - 0ff00000
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.000000]   Normal   [mem 0x0000000001000000-0x000000000fefffff]
[    0.000000]   HighMem  empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000001000-0x000000000008efff]
[    0.000000]   node   0: [mem 0x0000000000090000-0x000000000009ffff]
[    0.000000]   node   0: [mem 0x0000000000100000-0x00000000025adfff]
[    0.000000]   node   0: [mem 0x0000000002638000-0x000000000f170fff]
[    0.000000]   node   0: [mem 0x000000000f372000-0x000000000febcfff]
[    0.000000]   node   0: [mem 0x000000000feef000-0x000000000fef0fff]
[    0.000000]   node   0: [mem 0x000000000feff000-0x000000000fefffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000000fefffff]
[    0.000000] On node 0 totalpages: 64467
[    0.000000] free_area_init_node: node 0, pgdat c19adb00, node_mem_map cfbff02        0
[    0.000000]   DMA zone: 32 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 3998 pages, LIFO batch:0
[    0.000000]   Normal zone: 478 pages used for memmap
[    0.000000]   Normal zone: 60469 pages, LIFO batch:15
[    0.000000] Using APIC driver default
[    0.000000] ACPI: PM-Timer IO Port: 0x408
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.000000] IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-23
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[    0.000000] e820: [mem 0x10000000-0xf00f7fff] available for PCI devices
[    0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffff        ffff, max_idle_ns: 6370452778343963 ns
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pag        es: 63957
[    0.000000] Kernel command line: console=tty1 root=/dev/sda2 rootfstype=ext4        rootwait quiet video=vesafb intel_idle.max_cstate=1 processor.max_cstate=2 nohpe        t vga16fb.modeset=0 osmcdev=atv
[    0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Initializing CPU#0
[    0.000000] Initializing HighMem for node 0 (00000000:00000000)
[    0.000000] Memory: 244680K/257868K available (7827K kernel code, 334K rwdata        , 1764K rodata, 416K init, 368K bss, 13188K reserved, 0K cma-reserved, 0K highme        m)
[    0.000000] virtual kernel memory layout:
    fixmap  : 0xfffa3000 - 0xfffff000   ( 368 kB)
    pkmap   : 0xffc00000 - 0xffe00000   (2048 kB)
    vmalloc : 0xd0700000 - 0xffbfe000   ( 756 MB)
    lowmem  : 0xc0000000 - 0xcff00000   ( 255 MB)
      .init : 0xc19b5000 - 0xc1a1d000   ( 416 kB)
      .data : 0xc17a505f - 0xc19b3b80   (2106 kB)
      .text : 0xc1000000 - 0xc17a505f   (7828 kB)
[    0.000000] Checking if this processor honours the WP bit even in supervisor        mode...Ok.
[    0.000000] NR_IRQS:2304 nr_irqs:256 16
[    0.000000] CPU 0 irqstacks, hard=cf406000 soft=cf408000
[    0.000000] Console: colour dummy device 80x25
[    0.000000] console [tty1] enabled
[    0.000000] tsc: Fast TSC calibration using PIT
[    0.000000] tsc: Detected 1000.073 MHz processor
[    0.006670] Calibrating delay loop (skipped), value calculated using timer fr        equency.. 2000.48 BogoMIPS (lpj=3333576)
[    0.006676] pid_max: default: 32768 minimum: 301
[    0.006693] ACPI: Core revision 20150619
[    0.012717] ACPI: All ACPI Tables successfully acquired
[    0.012777] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.012783] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.013206] Disabled fast string operations
[    0.013233] Last level iTLB entries: 4KB 128, 2MB 0, 4MB 2
[    0.013236] Last level dTLB entries: 4KB 128, 2MB 0, 4MB 8, 1GB 0
[    0.013239] CPU: Genuine Intel(R) processor              1.00GHz (fam: 06, mo        del: 0d, stepping: 08)
[    0.013766] Performance Events: p6 PMU driver.
[    0.013779] ... version:                0
[    0.013782] ... bit width:              32
[    0.013785] ... generic registers:      2
[    0.013788] ... value mask:             00000000ffffffff
[    0.013791] ... max period:             000000007fffffff
[    0.013793] ... fixed-purpose events:   0
[    0.013796] ... event mask:             0000000000000003
[    0.014070] Enabling APIC mode:  Flat.  Using 1 I/O APICs
[    0.014577] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.049999] devtmpfs: initialized
[    0.049999] PM: Registering ACPI NVS region [mem 0x0008f000-0x0008ffff] (4096        bytes)
[    0.049999] PM: Registering ACPI NVS region [mem 0x0f171000-0x0f371fff] (2101        248 bytes)
[    0.049999] PM: Registering ACPI NVS region [mem 0x0febd000-0x0febefff] (8192        bytes)
[    0.049999] PM: Registering ACPI NVS region [mem 0x0fec0000-0x0feeefff] (1925        12 bytes)
[    0.049999] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma        x_idle_ns: 6370867519511994 ns
[    0.049999] xor: measuring software checksum speed
[    0.080004]    pIII_sse  :  2634.000 MB/sec
[    0.113337]    prefetch64-sse:  2870.400 MB/sec
[    0.113341] xor: using function: prefetch64-sse (2870.400 MB/sec)
[    0.113550] NET: Registered protocol family 16
[    0.114245] cpuidle: using governor ladder
[    0.114252] cpuidle: using governor menu
[    0.114586] ACPI: bus type PCI registered
[    0.114759] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xf0000000-0xff        ffffff] (base 0xf0000000)
[    0.114766] PCI: not using MMCONFIG
[    0.115077] PCI: Using configuration type 1 for base access
[    0.180042] raid6: mmxx1    gen()  1057 MB/s
[    0.236701] raid6: mmxx2    gen()  1212 MB/s
[    0.293390] raid6: sse1x1   gen()   776 MB/s
[    0.350009] raid6: sse1x2   gen()  1241 MB/s
[    0.406674] raid6: sse2x1   gen()  1374 MB/s
[    0.463369] raid6: sse2x1   xor()   897 MB/s
[    0.520008] raid6: sse2x2   gen()  1508 MB/s
[    0.576675] raid6: sse2x2   xor()   928 MB/s
[    0.576679] raid6: using algorithm sse2x2 gen() 1508 MB/s
[    0.576682] raid6: .... xor() 928 MB/s, rmw enabled
[    0.576686] raid6: using intx1 recovery algorithm
[    0.576771] ACPI: Added _OSI(Module Device)
[    0.576776] ACPI: Added _OSI(Processor Device)
[    0.576780] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.576784] ACPI: Added _OSI(Processor Aggregator Device)
[    0.580806] ACPI: Interpreter enabled
[    0.580834] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S1_        ] (20150619/hwxface-580)
[    0.580864] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S2_        ] (20150619/hwxface-580)
[    0.580887] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S3_        ] (20150619/hwxface-580)
[    0.580912] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S5_        ] (20150619/hwxface-580)
[    0.580933] ACPI: (supports S0)
[    0.580937] ACPI: Using IOAPIC for interrupt routing
[    0.580975] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xf0000000-0xff        ffffff] (base 0xf0000000)
[    0.582501] PCI: MMCONFIG at [mem 0xf0000000-0xffffffff] reserved in ACPI mot        herboard resources
[    0.582508] PCI: MMCONFIG for 0000 [bus00-3f] at [mem 0xf0000000-0xf3ffffff]        (base 0xf0000000) (size reduced!)
[    0.582512] PCI: Using MMCONFIG for extended config space
[    0.582564] PCI: Using host bridge windows from ACPI; if necessary, use "pci=        nocrs" and report a bug
[    0.590557] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    0.590571] acpi PNP0A08:00: _OSC: OS assumes control of [PCIeHotplug SHPCHot        plug AER PCIeCapability]
[    0.591167] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 0        0-3f] only partially covers this bridge
[    0.591479] PCI host bridge to bus 0000:00
[    0.591487] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.591494] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.591499] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.591505] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff win        dow]
[    0.591511] pci_bus 0000:00: root bus resource [mem 0x10000000-0xfebfffff win        dow]
[    0.591531] pci 0000:00:00.0: [8086:27a0] type 00 class 0x060000
[    0.591736] pci 0000:00:01.0: [8086:27a1] type 01 class 0x060400
[    0.591802] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    0.591975] pci 0000:00:07.0: [8086:27a3] type 00 class 0x110100
[    0.591996] pci 0000:00:07.0: reg 0x10: [mem 0x22a04000-0x22a04fff]
[    0.592224] pci 0000:00:1b.0: [8086:27d8] type 00 class 0x040300
[    0.592270] pci 0000:00:1b.0: reg 0x10: [mem 0x22a00000-0x22a03fff 64bit]
[    0.592361] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[    0.592556] pci 0000:00:1c.0: [8086:27d0] type 01 class 0x060400
[    0.592681] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.592880] pci 0000:00:1d.0: [8086:27c8] type 00 class 0x0c0300
[    0.592950] pci 0000:00:1d.0: reg 0x20: [io  0x2020-0x203f]
[    0.593084] pci 0000:00:1d.0: System wakeup disabled by ACPI
[    0.593224] pci 0000:00:1d.7: [8086:27cc] type 00 class 0x0c0320
[    0.593261] pci 0000:00:1d.7: reg 0x10: [mem 0x22a05000-0x22a053ff]
[    0.593350] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[    0.593422] pci 0000:00:1d.7: System wakeup disabled by ACPI
[    0.593552] pci 0000:00:1e.0: [8086:2448] type 01 class 0x060401
[    0.593796] pci 0000:00:1f.0: [8086:27b9] type 00 class 0x060100
[    0.593941] pci 0000:00:1f.0: can't claim BAR 7 [io  0x0400-0x047f]: address        conflict with ACPI CPU throttle [io  0x0410-0x0415]
[    0.593952] pci 0000:00:1f.0: quirk: [io  0x0500-0x053f] claimed by ICH6 GPIO
[    0.593960] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0680 (mask        000f)
[    0.593967] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 2 PIO at 1640 (mask        000f)
[    0.593977] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 4 PIO at 0300 (mask        001f)
[    0.594158] pci 0000:00:1f.1: [8086:27df] type 00 class 0x01018f
[    0.594185] pci 0000:00:1f.1: reg 0x10: [io  0x2058-0x205f]
[    0.594201] pci 0000:00:1f.1: reg 0x14: [io  0x2064-0x2067]
[    0.594217] pci 0000:00:1f.1: reg 0x18: [io  0x2050-0x2057]
[    0.594233] pci 0000:00:1f.1: reg 0x1c: [io  0x2060-0x2063]
[    0.594249] pci 0000:00:1f.1: reg 0x20: [io  0x2040-0x204f]
[    0.594447] pci 0000:00:1f.3: [8086:27da] type 00 class 0x0c0500
[    0.594515] pci 0000:00:1f.3: reg 0x20: [io  0xefa0-0xefbf]
[    0.594965] pci 0000:01:00.0: [10de:01d7] type 00 class 0x030000
[    0.594996] pci 0000:01:00.0: reg 0x10: [mem 0x21000000-0x21ffffff]
[    0.595014] pci 0000:01:00.0: reg 0x14: [mem 0x10000000-0x1fffffff 64bit pref        ]
[    0.595031] pci 0000:01:00.0: reg 0x1c: [mem 0x20000000-0x20ffffff 64bit]
[    0.595051] pci 0000:01:00.0: reg 0x30: [mem 0xfffe0000-0xffffffff pref]
[    0.595190] pci 0000:01:00.0: disabling ASPM on pre-1.1 PCIe device.  You can        enable it with 'pcie_aspm=force'
[    0.595206] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.595214] pci 0000:00:01.0:   bridge window [mem 0x20000000-0x21ffffff]
[    0.595223] pci 0000:00:01.0:   bridge window [mem 0x10000000-0x1fffffff 64bi        t pref]
MOD EDIT: For the love of all things Pi, please use the code tags </> or paste.osmc.io for code output!
@ATV1-canada
the logs are a pain in the form you pasted them. Please either use grab-logs -K and post the URL here. Or alternatively dmesg | paste-log
Have deleted part 2/3 to keep the thread clean and also have splitted this of the main thread as the USB Tuner troubleshooting is not related to the rest of the thread.
http://paste.osmc.io/irekuqaqed
that works way - easier - thanks
will look forward to your suggestions
Still going thru the details but at least it looks like for on eof your stick (1b80:e34c Afatech) the drivers are not included.
The other Stick would require a USB2 port, are you sure your USB Hub supports USB2? Because “connect to a high speed hub” seems to indicate differently.
hi
thanks for the first look and suggestions:
the powered USB hub states compliant for usb 2.0 and with a 2 amp psu
link below for what I am using
however will track down another powered USB hub to rule out this as a possible issue
look forward to your further suggestions
I am not a ATV1 owner so really searching in the dark here. But is the the ATV1 actually USB2? Maybe first try the USB Hub and Stick on another PC or MAC to check if everything is working.
It’s just that the page explictly syas it doesn’t run on USB 1.1 but maybe also because of the multi layer driver there might be other issues.
http://www.linuxtv.org/wiki/index.php/Hauppauge_WinTV-HVR-950Q#Sample_Kernel_Output
From a testing perspective as of today - have tested both ATSC USB tuners on my windows box with success. K-World 435Q and the Hauppage WinTV950Q. over the air TV via an antenna
further today
the Hauppauge 950Q tested on my old Boxee Box as this was were I had used it before.
further - both Tuners do work on the Myth Tv backend. I was hoping to lay the Myth Tv server to rest as it is cumbersome and approaching end of life for the hardware i have it on.
https://www.mythtv.org/wiki/Digital_Tuner_Cards
was really liking the TvHeadend sever all integrated into the ATV1 - with a USB Tuner. simple effective and and hopefully to be an enjoyable Christmas present for my nephew
on the Plus side from all the testing - the HD Homerun tuners works great with the OSMC TV Head end server and the apple tv. :smile:
thanks for all the help so far
kindest regards
m
ATV1 does have USB 2.0
Unfortunately I’ve never used a tuner card with the ATV1 so I’m not sure how they show up in logs when connected.
Back in CB2 days, I had a problem a USB Dongle not working and I seem to remember there was a way to get more detailled USB info (not just lsusb) ? Unfortunately I have been away from using both the ATV1 and Linux for a while so I can’t remember the details.
