I’ve been unsuccessfully trying to search the forum for the sync issue I have, so I’m opening a new topic.
The issue happens while watching movies/tv shows at random times - the audio and video become desynchronized so that audio is lagging behind video.
If I stop the playback and resume it again, audio and video become synchronized, but there is no telling when will it desynchronize again.
If I try to rewind 10 seconds as soon as desync happens, it will sync again.
The issue happens on a different number of files and it seems not connected to the files.
I’m running OSMC on RPI3 with an external 2TB usb HDD.
Add the following line: deb http://apt.osmc.tv stretch-devel main
I have updated my installation and I can confirm that there is no issue.
I’ve played fully the same file 2 times and it played without a single desync.
