Hi Guys,
I have set up my raspberry pi 2 with osmc and everything works fine. Now finally i tested to play an Audio CD with the help of an external dvd drive (USB and powered Hub). It works well, but i can’t do any navigation with the TV control. Normally it works perfect - playing mp3 files from the SD Card or playing films but in this case the navigation don’t work anytime.
I only searched for settings in the kodi visualization but is there a setting file where i can select the correct navigation buttons or something similar?
Thanks for your help!
Greats
Christoph
Can you be a little clearer about what doesn’t work?
I find, with that setup, that I can move up and down the tracks, select them stop them …
Derek
If i insert the CD, Audio play starts. Stop and Pause is possible, but getting forward to the next track is not possible although i have these two buttons on my remote control next to pause, play, stop buttons.
My question is, if it is possible to manually select these two buttons for these actions.
Christoph
What do you mean by ‘manually select buttons for’?
For me, pressing the ‘next track’ or ‘previous track’ button does just what it says.
Is this a special remote, have you had to provide any customising for it?
Derek
