Just got my Vero2, was running osmc on a Raspberry Pi 3 perviously, I love it, my only issue is I experience a delay in the sound when I start a video. It catches up fine and ends up not being an issue because it runs in sync once it starts. There is just a gap of 2-3 seconds where the video is playing without any audio. The delay seems less extreme since I got my Vero2 so I’m thinking it’s just a CPU issue. Just curious if anybody else experiences this and if anyone has found a fix.
A possible solution is to go into Settings->Audio and change the setting which causes the Audio channel to be stopped when idle for 1 minute - change it to never.
Do you have a small file that can reproduce the problem?
Are you using passthrough? There can be a slight audio gap when the signal changes, same with Adjust Refresh Rate.
I must have a different version but I went Settings–>System–>Audio Output and found “Keep Audio Device Alive” it was set to 1min so I changed it to Always. Went right back out and started a file and had the delay.
@sam_nazarko I will look for a smaller file. I am not using passthrough. The issue happens with literally every video being played though, I have not tested directly from USB or the SD card, but from my NAS it will happen on every file regardless of size it also happens when I am playing videos through the add-ons.
