even if the analog device is selected kodi is playing the sound through hdmi when my beamer is connected.
how do i disable hdmi as the audio device?
Hello
I somehow managed to miss this post. I’ll see if I can come up with a solution shortly.
I had a look at this. The SoC supports dual audio which can be advantageous at times [1]; but I can understand this can be a nuisance if you don’t want audio coming out of the projector speakers when you have a dedicated system.
You can adjust with alsamixer, but this may not always work depending on how audio is routed. If you can do so, just mute the audio on the projector. It will cause no issues.
[1] No kodi sound output if spotify-connect-web server is active
ok, i did so. thx for your help!
