A while ago I upgraded to Kodi 18 to 19. Currently I’m on the 2023.01-01 version. My Vero is connected via optical to my Logitech Z5500 audio set.
The issues I have, that I did not have on Kodi 18, are:
- Sound goes out of sync slowly. It’s fine on the average TV show but during movies it becomes noticeable rather quickly. Pausing playback makes the problem way worse a lot faster. Stopping playback and restarting it fixes it temporarily.
- Sound occasionally cuts out for a second. The problem is not the source file; if I play the same 30 minutes again the problem might not occur at all, or at wildly different times.
The audio set, while old, doesn’t seem to be the issue. My gaming PC is connected to it on direct input and that sound doesn’t cut out at all.
I’ve previously reported another issue: https://discourse.osmc.tv/t/dual-audio-on-hdr-content-with-kodi-19-4/ and I’m still using the workaround supplied by grahamh. Could that be related?
To be clear; I did not have any of these problems on Kodi 18.
Any ideas?
reproduce the issue
upload the log set (all configs and logs!) either using the Log Uploader
method within the My OSMC menu in the GUI or the ssh
method invoking command grab-logs -A
URL: https://paste.osmc.tv/duxupequse
I wasn’t paying attention all the time but I did hear the sound cut out at least once, around the 32 minute mark. Sound was noticeably out of sync by then as well.
If you need any more info from me regarding this issue please let me know.
I’m considering just downgrading back to Kodi 18 as it didn’t have any issues. And that just feels wrong.
