recently I get crazy audio noises instead of the video audio if I try to start a video file. It does not happen all of the time so it is not easy to replicate. If I stop the video and start again it works fine. This started when I disabled frame rate adjustments before starting a video because I did not like the 2-3 seconds of black while the video already started.
Can this really be the cause and if yes is there something else I can do?
I would prefer not to go back to the black picture at the beginning of videos.
hm it seems to happen the first time after restarting kodi most of the time. Does somebody have an idea what to do about it?
reproduce the issue
upload the log set (all configs and logs!) either using the
thanks, I will try to reproduce it.
