With the TV turned On the audio can only be heard with vc4-Hdmi settings with the TV turned off however it also works configured as snd_rpi_ hifiberry_dac.
As Sam says, the HiFiBerry people would be the ones to ask. OSMC uses ALSA just like any other Linux on Pi. The instructions for OSMC on their site look OK but a bit old.
If you post logs with a timeline of what you are doing (when you plugged/unplugged the TV) that would help.
I tried to contact the seller but he sent me back to the link I indicated in the initial post.
I’m definitely doing something wrong that escapes me at the moment.
Currently, to be able to hear audio on the PI setting of the sound card I have to set the Soundcard Overall item to none and not select the hiFiBerry-dac sound card.
vc4-hdmi, MAI PCM i2s-hifi-0 and vc4-hdmi, SAM SAMSUNG on HDMI
they are present only if set PI setting of the sound card I have to set the Soundcard Overall item to none and they allow me to hear audio output from both HDMI and soundcard.
Hi, I carried out further investigations and discovered that if I disconnect the optical connection that goes from the TV to the amplifier the audio can be heard correctly.
In my configuration the TV is connected with an HDMI cable to the Raspberry and with an optical cable to the audio amplifier (to hear the TV audio on the amplifier when I am not using the Raspberry).
On the Raspberry the sound card output is connected to the amplifier (to hear audio on the amplifier) .
Now when I use Kodi the audio comes out both from the TV and from the Raspberry sound card and I have to lower the TV audio to 0 so as not to hear the sound from both the TV speakers and the amplifier.
Now I noticed that when I launch retropie to hear the sound with TV turned on I have to disconnect the optical cable.
Is there no way to configure Osmc so that it behaves like Kodi by playing audio from both the TV and the Audio card?
I’ve never seen or heard of any display that has options for a connected device to change its toslink options. Typically in a situation like this where there is an older amplifier being used one would just connect the RPi to the TV via HDMI and the TV to the amplifier via optical and change the TV’s settings to mute internal speakers and output via the optical.
Thanks for the reply. I have already disabled the speaker output on the TV and enabled only optical output.
The problem is that when I run RetroPie to hear audio I have to disconnect the optical cable from the TV to hear it from the sound card’s audio output and I don’t understand why.
reproduce the issue
