I don’t get audio from all channels. The problem is not connected to any specifik codecs. I get AC-3 audio from one channel on not from another. Anyone else encountering this?
If you have configured your audio settings correctly
then you would need to post debug logs that reproduce the issue in order for anyone to assist you in correcting the error.
reproduce the issue
upload the log set (all configs and logs!) either using the
I finally came around to reproduce the error. But now it works fine. Sorry to have taken up anyones time!
